path: root/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-19configs: lx2160aqds_tfa_defconfig: enable DM_ETH and relatedIoana Ciornei
Enable CONFIG_DM_ETH and CONFIG_DM_MDIO and related configs for the LX2160AQDS board. Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com> Reviewed-by: Razvan Ionut Cirjan <razvanionut.cirjan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-03-30configs: lx2160a: Enable FSPI supportKuldeep Singh
Enable FSPI controller support. So, flash environment can now be used. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-03-30configs: lx2160a: Enable GIC_V3_ITS configWasim Khan
Enable GIC_V3_ITS config to program GIC LPI configuration table. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-06configs: Resync with savedefconfigTom Rini
2020-01-24configs: fsl-layerscape: secure_boot: Enable setexpr commandUdit Agarwal
setexpr command is used while running secure boot (chain of trust with confidentiality) feature. Enable CONFIG_CMD_SETEXPR to enable setexpr command. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-24board: fsl: lx2160a: free up arch_misc_initAlex Marginean
Currently LX2 board code uses arch_misc_init to set up the board mux on RDB and QDS. Move this code to misc_init_r. This is consistent with LS gen 2 and T series SoCs/boards. Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-24configs: lx2160a: enable CONFIG_OF_BOARD_FIXUP for SECURE_BOOT defconfigWasim Khan
lx2160a rev1 and rev2 SoC has different pcie controller. The pcie controller device tree node fields "compatible" and registers names needs to be updated accordingly. Enable CONFIG_OF_BOARD_FIXUP to apply board_fix_fdt which updates the "compatible" and registers names. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-24pci: layerscape: Common device tree fixup for NXP SoCsWasim Khan
Add Common device tree fixup for NXP SoCs. Based on SoC and revision call pcie_layerscape or pcie_layerscape_gen4 fixup. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-26configs: lx2160a: Enable FSPI_AHB_EN_4B configKuldeep Singh
Enable 4-byte Fast Read command for Flexspi AHB mode Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-29configs/lx2160a: Add CONFIG_ENV_SECT_SIZE in defconfigPriyanka Jain
Define CONFIG_ENV_SECT_SIZE as 0x20000 in lx2160a related defconfigs: lx2160ardb_tfa_defconfig, lx2160ardb_tfa_SECURE_BOOT_defconfig, lx2160aqds_tfa_defconfig, lx2160aqds_tfa_SECURE_BOOT_defconfig Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-11Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC. - Few bug fixes and updates related to SPI, hwconfig, ethernet, fsl-layerscape, pci, icid, PSCI
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-25configs: Resync with savedefconfigTom Rini
2019-08-22configs: lx2160: enable DM support for pcf2127 rtcChuanhua Han
Enable related configs on all lx2160ardb boards to support pcf2127 rtc DM feature. Also remove SYS_I2C_MXC_I2Cx, where x is from 1 to 8 from Kconfig. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-05-22armv8: lx2160a: enable PCIe supportHou Zhiqiang
Enable the PCIe Gen4 controller driver and e1000 for LX2160ARDB and LX2160AQDS boards. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19lx2160aqds : Add support for LX2160AQDS platformPankaj Bansal
LX2160AQDS is a development board that supports LX2160A family SoCs. This patch add base support for this board. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> [PK: Sqaush patch for "secure boot defconfig" & add maintainer] Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
