path: root/configs/lwmon5_defconfig
2015-10-11Revert "powerpc: ppc4xx: remove lwmon5 support"Stefan Roese
This reverts commit 8fe11b8901a31d11990488c82bc23612589d57be. I'll add support to lwmon5 in the next patch and will remove support for the broken lcd4_lwmon5 as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-02powerpc: ppc4xx: remove lwmon5 supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Remove CONFIG_LWMON5 references. (Also, remove undefined CONFIG_WD_MAX_RATE while I am here.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
