path: root/configs/lschlv2_defconfig
2019-01-07configs: Resync with savedefconfigTom Rini
2018-06-05arm: kirkwood: lsxl: Add SPI driver model supportMichael Walle
This patch shows how to enable driver model support for the LS-CHLv2 and LS-XHL boards. There are a couple of open questions: - do I need the u-boot,dm-pre-reloc tags in the device tree? - should mach/config.h define CONFIG_DM_SEQ_ALIAS? - how can we split this patch or are there any other pending patches which does the same and I didn't catch these. This patch is based on the http://git.denx.de/u-boot-marvell.git (master branch) and needs the following patches, which are still pending: https://patchwork.ozlabs.org/patch/909618/ https://patchwork.ozlabs.org/patch/909617/ https://patchwork.ozlabs.org/patch/909973/ Signed-off-by: Michael Walle <michael@walle.cc> Tested-by: Michael Walle <michael@walle.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05enable CONFIG_DISTRO_DEFAULTS for LS-CHLv2 boardMichael Walle
Synchronize it with the LS-XHL board. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-29ARM: kirkwood: Add device-tree for lschlv2 & lsxhlChris Packham
Import the dts files from Linux 4.17 and enable CONFIG_OF_CONTROL. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14net: add Kconfig for MVGBEChris Packham
Add Kconfig for MVGBE and update boards to select this. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_MVSATA_IDE to KconfigTuomas Tynkkynen
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
