path: root/configs/ls2088ardb_qspi_defconfig
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-01arm64: ls2088ardb: Add distro boot supportZhang Ying-22455
Include common config_distro_defaults.h and config_distro_bootcmd.h for u-boot enviroments to support automatical distro boot which scan boot.scr from external storage devices(e.g. SD/USB/SATA/SCSI disk) and execute autoboot script. Tested on ls2088ardb with automatically boot Ubuntu from SD card or USB disk, if it fails to detect external storage disk, fall back to nor/qspi boot. Signed-off-by: Zhang Ying-22455 <ying.zhang22455@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add QSPI-boot supportPriyanka Jain
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC. LS2088ARDB RevF Board has limitation that QIXIS can not be accessed. CONFIG_FSL_QIXIS is not enabled. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
