Apple SoCs have an integrated NVMe controller that isn't connected
over a PCIe bus. In preparation for adding support for this NVMe
controller, split out the PCI support into its own file. This file
is selected through a new CONFIG_NVME_PCI Kconfig option, so do
a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
Move the SATA options inside an 'if SATA' part, so they are grouped.
Fix the 'Complient' typo while we are here.
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
In order to finish moving this symbol to Kconfig for all platforms, we
need to do a few more things. First, for all platforms that define this
to a function, introduce CONFIG_DYNAMIC_SYS_CLK_FREQ, similar to
CONFIG_DYNAMIC_DDR_CLK_FREQ and populate clock_legacy.h. This entails
also switching all users from CONFIG_SYS_CLK_FREQ to get_board_sys_clk()
and updating a few preprocessor tests.
With that done, all platforms that define a value here can be converted
to Kconfig, and a fall-back of zero is sufficiently safe to use (and
what is used today in cases where code may or may not have this
available). Make sure that code which calls this function includes
<clock_legacy.h> to get the prototype.
CONFIG_VID
CONFIG_VOL_MONITOR_INA220
CONFIG_VOL_MONITOR_IR36021_READ
CONFIG_VOL_MONITOR_IR36021_SET
CONFIG_VOL_MONITOR_LTC3882_READ
CONFIG_VOL_MONITOR_LTC3882_SET
To finish this migration, we first need to introduce CONFIG_SPL_VID as
some platforms only use this code in full U-Boot while others use it in
SPL as well. To make the Kconfig logic clearer, guard all of the
sub-options with a if VID || SPL_VID check. Finally, add Kconfig
options for the remaining related options that did not previously have
one.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
Convert SYS_I2C_EARLY_INIT to Kconfig, and make it depend on
SPL_SYS_I2C_LEGACY. Remove the weak implementation as it's either
something that needs to exist for real, or shouldn't be called.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
Use moveconfig.py script to convert below defines to Kconfig and move
these entries to defconfigs.
CONFIG_CORTINA_FW_ADDR
CONFIG_CORTINA_FW_LENGTH
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson <stcarlso@linux.microsoft.com>
[Squashed ls2088a patch to fix compilation]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
Enable DM_GPIO and CMD_GPIO for board ls2088ardb
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb,
ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb.
- Add GICv3 support for ls1028a, ls2088a, ls1088a.
- Add lpuart support on ls1028aqds.
- Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based
platforms.
Enable CONFIG_DM_ETH and CONFIG_DM_MDIO and related configs for the
LS2088ARDB board.
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Enable GIC_V3_ITS config to initialize the GIC redistributor
tables.
Reviewed-by: Wasim Khan <wasim.khan@nxp.com>
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
CONFIG_PHY_CORTINA
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
- Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC.
- Few bug fixes and updates related to SPI, hwconfig, ethernet,
fsl-layerscape, pci, icid, PSCI
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict
with UEFI secure boot.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls208xardb
and ls208xaqds defconfigs that missing one of them or more.
enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK
Support sata for all ls208xa defconfigs
Signed-off-by: Peng Ma <peng.ma@nxp.com>
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G.
Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com>
This enables the folowing to Kconfig:
CONFIG_BLK
CONFIG_DM_MMC
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
