path: root/configs/ls2085ardb_defconfig
2015-10-29armv8: ls2085a: Add support of random MAC addressPrabhakar Kushwaha
Add support of setting RANDOM MAC address if env variable not available. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-20armv8/ls2085a/defconfig: Enable FSL_DSPI, OF_CONTROL and DM supportHaikun.Wang@freescale.com
Freescale DSPI driver has been converted to Driver Model. The new driver depends on OF_CONTROL, DM, DM_SPI. This patch enable FSL_DSPI and its dependence configure options. Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23armv8/ls2085ardb: Add support of LS2085ARDB platformYork Sun
The LS2085ARDB is a evaluation platform that supports LS2085A family SoCs. This patch add sbasic support for the platform. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
