path: root/configs/ls2085aqds_defconfig
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8: ls2085a: Add support of random MAC addressPrabhakar Kushwaha
Add support of setting RANDOM MAC address if env variable not available. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-20armv8/ls2085a/defconfig: Enable FSL_DSPI, OF_CONTROL and DM supportHaikun.Wang@freescale.com
Freescale DSPI driver has been converted to Driver Model. The new driver depends on OF_CONTROL, DM, DM_SPI. This patch enable FSL_DSPI and its dependence configure options. Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23armv8/ls2085aqds: Add support of LS2085AQDS platformYork Sun
The LS2085AQDS is an evaluatoin platform that supports the LS2085A family SoCs. This patch add basic support of the platform. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
