path: root/configs/ls2081ardb_defconfig
2020-05-08configs: Resync with savedefconfigTom Rini
2020-04-30Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb, ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb. - Add GICv3 support for ls1028a, ls2088a, ls1088a. - Add lpuart support on ls1028aqds. - Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based platforms.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28configs: ls208xa: Enable GIC_V3_ITS configHou Zhiqiang
Enable GIC_V3_ITS config to initialize the GIC redistributor tables. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-03Convert CONFIG_PHY_CORTINA to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHY_CORTINA Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-02-19configs: ls208xa: enable sata configs for all ls208xa defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls208xardb and ls208xaqds defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls208xa defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-23armv8: ls2080ardb: Add LS2081ARDB board supportPriyanka Jain
LS2081ARDB board is similar to LS2080ARDB board with few differences It hosts LS2081A SoC Default boot source is QSPI-boot It does not have IFC interface RTC and QSPI flash device are different It provides QIXIS access via I2C Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
