path: root/configs/ls2080ardb_SECURE_BOOT_defconfig
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-06armv8: LS2080A_SECURE_BOOT: Enable CONFIG_FSL_LS_PPA.Udit Agarwal
Adds config CONFIG_FSL_LS_PPA and CONFIG_FSL_CAAM in LS2080AQDS and LS2080ARDB secure boot defconfig. Removes CONFIG_FIT, as with CONFIG_FSL_LS_PPA enabled, CONFIG_FIT is selected. Removes CONFIG_SPL_RSA as in NOR boot SPL boot is not done. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-17armv8: ls2080a: Drop macro CONFIG_LS2080AYork Sun
Use CONFIG_ARCH_LS2080A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: fsl-layerscape: Fix SECURE_BOOT configYork Sun
Without a prompt in Kconfig, SECURE_BOOT cannot be selected by defconfig. The option was dropped unintentionally when defconfig files were cleaned up. Three targets were impacted ls1043ardb_SECURE_BOOT, ls2080ardb_SECURE_BOOT, ls2080aqds_SECURE_BOOT. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-18armv8: ls2080a: Enable PCIe in defconfigsMinghuan Lian
The patch enables PCIe in ls2080a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-04Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02armv8: fsl-layerscape: Move SECURE_BOOT to KconfigYork Sun
Move from CONFIG_SYS_EXTRA_OPTIONS to Kconfig option. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-07armv8: ls2080: Enable CONFIG_DM_USB in defconfigsSriram Dash
Enables driver model flag CONFIG_DM_USB for LS2080A platform defconfigs. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-27efi_loader: Select bounce buffers for known-bad boardsAlexander Graf
We know for certain that we have 32bit DMA hardware, but 64bit addresses on LS2085A and ZynqMP, so let's enable EFI bounce buffers for all defconfigs on these SoCs. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-29armv8: ls2080rdb: ls2080qds: Add secure boot supportSaksham Jain
Sec_init has been called at the beginning to initialize SEC Block (CAAM) which is used by secure boot validation later for both ls2080a qds and rdb. 64-bit address in ESBC Header has been enabled. Secure boot defconfigs are created for boards (NOR boot). Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
