path: root/configs/ls2080aqds_defconfig
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-27efi_loader: Select bounce buffers for known-bad boardsAlexander Graf
We know for certain that we have 32bit DMA hardware, but 64bit addresses on LS2085A and ZynqMP, so let's enable EFI bounce buffers for all defconfigs on these SoCs. Signed-off-by: Alexander Graf <agraf@suse.de>
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
