path: root/configs/ls2080a_simu_defconfig
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-04-17armv8: ls2080a: Drop macro CONFIG_LS2080AYork Sun
Use CONFIG_ARCH_LS2080A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27efi_loader: Select bounce buffers for known-bad boardsAlexander Graf
We know for certain that we have 32bit DMA hardware, but 64bit addresses on LS2085A and ZynqMP, so let's enable EFI bounce buffers for all defconfigs on these SoCs. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
