path: root/configs/ls1088ardb_sdcard_qspi_defconfig
2018-01-30armv8: ls1088a: Add CONFIG_SPI_FLASH_SPANSION to sdcard defconfigsAshish Kumar
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-17armv8: ls1088: Add USB and PCI configs in SD-BOOT defconfigAshish Kumar
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-12-06armv8: ls1088a: Unset USE_BOOTCOMMAND in defconfigAshish Kumar
Unset USE_BOOTCOMMAND for all ls1088 defconfig files to fix redefinition error. USE_BOOTCOMMAND was introduced in commit b6251db8c3f ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND"). Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-15armv8: ls1088ardb: Add distro boot supportAshish Kumar
Distro boot support gives flexibility to run distro RFS like Ubuntu being deployed from SD card or SATA drive. If it fails to detect external storage, fall back to qspi/sd boot. Enable this by default in RDB's defconfig by selecting CONFIG_DISTRO_DEFAULTS Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Zhang Ying <zhangying@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-15armv8: ls1088ardb: Add SD boot support for ls1088Ashish Kumar
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
