CONFIG_SYS_NAND_ONFI_DETECTION
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_QSPI_BOOT
CONFIG_SYS_FSL_DDR4
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson <stcarlso@linux.microsoft.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
Enable DM_GPIO and CMD_GPIO for board ls1088ardb
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Enable the CMD_MDIO Kconfig option by removing the "is not set"
indication from all the defconfigs for this SoC.
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb,
ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb.
- Add GICv3 support for ls1028a, ls2088a, ls1088a.
- Add lpuart support on ls1028aqds.
- Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based
platforms.
Enable CONFIG_DM_ETH and CONFIG_DM_MDIO and related configs for the
LS1088ARDB board.
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Enable GIC_V3_ITS config to initialize the GIC redistributor
tables.
Reviewed-by: Wasim Khan <wasim.khan@nxp.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
- Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC.
- Few bug fixes and updates related to SPI, hwconfig, ethernet,
fsl-layerscape, pci, icid, PSCI
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict
with UEFI secure boot.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1088ardb
and ls1088aqds defconfigs that missing one of them or more.
Support sata for all ls1088a defconfigs
Signed-off-by: Peng Ma <peng.ma@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G.
Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com>
This enables the folowing to Kconfig:
CONFIG_BLK
CONFIG_DM_MMC
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
