path: root/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig
2019-02-19configs: ls1088a: enable sata configs for all ls1088a defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1088ardb and ls1088aqds defconfigs that missing one of them or more. Support sata for all ls1088a defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-06ls1088a: Move CONFIG_FSL_QSPI to defconfigAshish Kumar
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-26configs: Disable 4k erase sector size for spansion "s25fs512s" flashAshish Kumar
4K erase size is used only in case of hydrid mode which is not supported on any NXP platform with flash "s25fs512s". Supported mode is uniform sector, with erase size 256kiB. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-05-09armv8: ls1088a: Move CONFIG_BOOTARGS and CONFIG_CMD_GREPENV to defconfigAshish Kumar
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-14configs: Resync with savedefconfigTom Rini
2018-02-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2018-02-09armv8: ls1088a: qspi: Enable XIP mode above 16 MB addressesRajat Srivastava
Currently in LS1088A, XIP mode in QSPI works up to 16 MB addresses. This patch enables QSPI support in XIP mode for addresses above 16 MB as well. Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-12-06armv8: LS1088A_QSPI: Add secure boot defconfigs for QSPI boot.Udit Agarwal
Add the secure boot defconfigs for QSPI boot on LS1088ARDB and LS1088AQDS platforms. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Vinitha Pillai-B57223 <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
