We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Instead of defining Kconfig macros in header file, move them to
defconfig files.
Signed-off-by: York Sun <york.sun@nxp.com>
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but
existed in some include files; fix those up here.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
PPA loading during SPL stage is not required for nornal
SD boot scenario.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
include/configs/ls1046aqds.h
include/configs/ls1046ardb.h
Tested on ls1046ardb with automatically boot Ubuntu from SD card or
USB disk, if it fails to detect external storage disk, fall back to
qspi boot.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Move the macro to defconfig to take effect globally.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_SPL_BOARD_INIT is used for SPL boot. It is only enabled for
secure boot at this moment. Enable it in defconfig files for SPL
build.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
configs/ls1046aqds_defconfig
configs/ls1046aqds_nand_defconfig
configs/ls1046aqds_qspi_defconfig
configs/ls1046aqds_sdcard_ifc_defconfig
configs/ls1046aqds_sdcard_qspi_defconfig
configs/ls1046ardb_emmc_defconfig
configs/ls1046ardb_qspi_defconfig
configs/ls1046ardb_sdcard_defconfig
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
The patch enables PCIe and E1000 in ls1046a related defconfigs.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
[trini: Fix sniper and kc1 migration]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
LS1046ARDB Specification:
Memory subsystem:
* 8GByte DDR4 SDRAM (64bit bus)
* 512 Mbyte NAND flash
* Two 64 Mbyte high-speed SPI flash
* SD connector to interface with the SD memory card
* On-board 4G eMMC
Ethernet:
* Two XFI 10G ports
* Two SGMII ports
* Two RGMII ports
PCIe:
* PCIe1 (SerDes2 Lane0) to miniPCIe slot
* PCIe2 (SerDes2 Lane1) to x2 PCIe slot
* PCIe3 (SerDes2 Lane2) to x4 PCIe slot
SATA:
* SerDes2 Lane3 to SATA port
USB 3.0: one super speed USB 3.0 type A port
one Micro-AB port
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
