path: root/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig
2019-06-19configs/ls1046ardb_*: disable CONFIG_SPI_FLASH_USE_4K_SECTORSMaciej Pijanowski
With this setting enabled, the on-board QSPI cannot be properly flashed. There are no error messages, but the simple write / read / compare tests fail. This is already disabled in the qspi and tfa defconfigs for the LS1046ARDB platform. Signed-off-by: Maciej Pijanowski <maciej.pijanowski@3mdeb.com> Cc: piotr.krol@3mdeb.com Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-22configs: Unset CONFIG_SPI_BAR for all LS1046A defconfigsRajat Srivastava
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22configs: ls1046: Update mtd-id for QSPI nor in mtdparts variableKuldeep Singh
Update mtd-id for QSPI nor due to change introduced in mtd/spi in linux 5.0. commit 84d043185dbe ("spi: Add a driver for the Freescale/NXP QuadSPI controller") This modification is only for linux kernel version >= 5.0. To use bootargs for kernel < 5.0, use the following bootargs CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:2m(uboot),14m(free)" CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:2m(uboot),14m(free)" Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-03board: ls1046a: enable EFI_LOADER_BOUNCE_BUFFERMian Yousaf Kaukab
EFI applications need bounce buffers to work properly on these platforms. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-26armv8: ls1046ardb: ls1046aqds: Move SPL macros to defconfigYork Sun
Instead of defining Kconfig macros in header file, move them to defconfig files. Signed-off-by: York Sun <york.sun@nxp.com>
2018-04-28Cleanup CONFIG_SPL_SERIAL_SUPPORT migrationAlex Kiernan
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but existed in some include files; fix those up here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-02Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1046aqds.h include/configs/ls1046ardb.h
2017-08-01arm64: ls1046ardb: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01armv8: ls1046a: move CONFIG_CMD_USB to defconfigQianyu Gong
Move the macro to defconfig to take effect globally. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-01armv8: ls1046a: Enable spl_board_init() functionYork Sun
CONFIG_SPL_BOARD_INIT is used for SPL boot. It is only enabled for secure boot at this moment. Enable it in defconfig files for SPL build. Signed-off-by: York Sun <york.sun@nxp.com>
2017-04-24armv8: ls104xardb: Secure Boot: enable PPA support for eMMC/SD and NAND bootSumit Garg
Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17arm: ls1046ardb: Add SD secure boot targetRuchika Gupta
- Add SD secure boot target for ls1046ardb. - Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. - CONFIG_MAX_SPL_SIZE is limited to 90KB. SPL is copied to OCRAM (128K) where 32K are reserved for use by boot ROM and 6K for the header. - Reduce the size of CAAM driver for SPL Blobification functions and descriptors, that are not required at the time of SPL are disabled. Further error code conversion to strings is disabled for SPL build. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
