path: root/configs/ls1046ardb_qspi_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-02Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1046aqds.h include/configs/ls1046ardb.h
2017-08-01arm64: ls1046ardb: Add distro boot supportQianyu Gong
Tested on ls1046ardb with automatically boot Ubuntu from SD card or USB disk, if it fails to detect external storage disk, fall back to qspi boot. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01armv8: ls1046a: move CONFIG_CMD_USB to defconfigQianyu Gong
Move the macro to defconfig to take effect globally. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-01-27armv8: ls1046a: enable usb in defconfigTang Yuantian
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18fsl PPA: enable PPA for ls1043ardb and ls1046ardbHou Zhiqiang
Enable PPA for ls1043ardb NOR boot and ls1046ardb QSPI boot. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1046a: Enable PCIe and E1000 in defconfigsMinghuan Lian
The patch enables PCIe and E1000 in ls1046a related defconfigs. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-05armv8: QSPI: Add AHB bus 16MB+ size supportYuan Yao
The default configuration for QSPI AHB bus can't support 16MB+. But some flash on NXP layerscape board are more than 16MB. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14armv8: ls1046ardb: Add LS1046ARDB board supportMingkai Hu
LS1046ARDB Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 512 Mbyte NAND flash * Two 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card * On-board 4G eMMC Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports PCIe: * PCIe1 (SerDes2 Lane0) to miniPCIe slot * PCIe2 (SerDes2 Lane1) to x2 PCIe slot * PCIe3 (SerDes2 Lane2) to x4 PCIe slot SATA: * SerDes2 Lane3 to SATA port USB 3.0: one super speed USB 3.0 type A port one Micro-AB port UART: supports two UARTs up to 115200 bps for console Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
