path: root/configs/ls1046ardb_emmc_defconfig
2019-06-19configs/ls1046ardb_*: disable CONFIG_SPI_FLASH_USE_4K_SECTORSMaciej Pijanowski
With this setting enabled, the on-board QSPI cannot be properly flashed. There are no error messages, but the simple write / read / compare tests fail. This is already disabled in the qspi and tfa defconfigs for the LS1046ARDB platform. Signed-off-by: Maciej Pijanowski <maciej.pijanowski@3mdeb.com> Cc: piotr.krol@3mdeb.com Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-22configs: Unset CONFIG_SPI_BAR for all LS1046A defconfigsRajat Srivastava
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22configs: ls1046: Update mtd-id for QSPI nor in mtdparts variableKuldeep Singh
Update mtd-id for QSPI nor due to change introduced in mtd/spi in linux 5.0. commit 84d043185dbe ("spi: Add a driver for the Freescale/NXP QuadSPI controller") This modification is only for linux kernel version >= 5.0. To use bootargs for kernel < 5.0, use the following bootargs CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:2m(uboot),14m(free)" CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:2m(uboot),14m(free)" Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-03board: ls1046a: enable EFI_LOADER_BOUNCE_BUFFERMian Yousaf Kaukab
EFI applications need bounce buffers to work properly on these platforms. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19configs: ls1046a: enable sata configs for all ls1046a defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1046ardb and ls1046aqds defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls1046a defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-26armv8: ls1046ardb: ls1046aqds: Move SPL macros to defconfigYork Sun
Instead of defining Kconfig macros in header file, move them to defconfig files. Signed-off-by: York Sun <york.sun@nxp.com>
2018-04-28Cleanup CONFIG_SPL_SERIAL_SUPPORT migrationAlex Kiernan
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but existed in some include files; fix those up here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-02Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1046aqds.h include/configs/ls1046ardb.h
2017-08-01armv8: ls1046a: move CONFIG_CMD_USB to defconfigQianyu Gong
Move the macro to defconfig to take effect globally. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-01armv8: ls1046a: Enable spl_board_init() functionYork Sun
CONFIG_SPL_BOARD_INIT is used for SPL boot. It is only enabled for secure boot at this moment. Enable it in defconfig files for SPL build. Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-28fsl-layerscape/ls104xardb: enable PPA support for eMMC/SD and NAND bootHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-01-27armv8: ls1046a: enable usb in defconfigTang Yuantian
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1046a: Enable PCIe and E1000 in defconfigsMinghuan Lian
The patch enables PCIe and E1000 in ls1046a related defconfigs. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
