path: root/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig
2020-09-23configs: ls1012a/ls1046a: Add CONFIG_ENV_OVERWRITE in defconfigKuldeep Singh
CONFIG_ENV_OVERWRITE disables write protection on various environment variables like "ethaddr" and "serial". Enable this config in LS1046A and LS1012A defconfigs. This resolves an error while setting multiple values of "ethaddr" variable. Before the change: => setenv ethaddr 00:E0:0C:00:06:0 => setenv ethaddr 00:E0:0C:00:06:1 Error: Can't overwrite "ethaddr" Error inserting "ethaddr" variable, errno=1 After the change: => setenv ethaddr 00:E0:0C:00:06:0 => setenv ethaddr 00:E0:0C:00:06:1 Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-27pci: layerscape: Add specific config entry for RC and EP mode driverHou Zhiqiang
Add Root Complex and Endpoint mode specific config entries, such that it's feasible to enable the RC and/or EP mode driver indepently. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-19configs: ls1046a: Move SPI_FLASH_SPANSION to defconfigKuldeep Singh
Enable CONFIG_SPI_FLASH_SPANSION in defconfigs of LS1046ARDB and LS1046AQDS which have two spansion flases i.e s25fs512s each of size 64M. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-03-30dm: arm64: ls1046a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1046A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-06configs: Resync with savedefconfigTom Rini
2020-01-24configs: fsl-layerscape: secure_boot: Enable setexpr commandUdit Agarwal
setexpr command is used while running secure boot (chain of trust with confidentiality) feature. Enable CONFIG_CMD_SETEXPR to enable setexpr command. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04configs: ls104x/ls108x/ls208x: Build the raw NAND core with TFABOOTMiquel Raynal
Enabling TFABOOT configuration will compile-in a call to nand_read in the boot sequence. Handle the situation by also selecting officially the raw NAND core in this case. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-11Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC. - Few bug fixes and updates related to SPI, hwconfig, ethernet, fsl-layerscape, pci, icid, PSCI
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-03-03board: ls1046a: enable EFI_LOADER_BOUNCE_BUFFERMian Yousaf Kaukab
EFI applications need bounce buffers to work properly on these platforms. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-06armv8: ls1046aqds: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1046aqds_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - FMAN address changes for TFABOOT - define BOOTCOMMAND for TFABOOT Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
