In order to finish moving this symbol to Kconfig for all platforms, we
need to do a few more things. First, for all platforms that define this
to a function, introduce CONFIG_DYNAMIC_SYS_CLK_FREQ, similar to
CONFIG_DYNAMIC_DDR_CLK_FREQ and populate clock_legacy.h. This entails
also switching all users from CONFIG_SYS_CLK_FREQ to get_board_sys_clk()
and updating a few preprocessor tests.
With that done, all platforms that define a value here can be converted
to Kconfig, and a fall-back of zero is sufficiently safe to use (and
what is used today in cases where code may or may not have this
available). Make sure that code which calls this function includes
<clock_legacy.h> to get the prototype.
CONFIG_VID
CONFIG_VOL_MONITOR_INA220
CONFIG_VOL_MONITOR_IR36021_READ
CONFIG_VOL_MONITOR_IR36021_SET
CONFIG_VOL_MONITOR_LTC3882_READ
CONFIG_VOL_MONITOR_LTC3882_SET
To finish this migration, we first need to introduce CONFIG_SPL_VID as
some platforms only use this code in full U-Boot while others use it in
SPL as well. To make the Kconfig logic clearer, guard all of the
sub-options with a if VID || SPL_VID check. Finally, add Kconfig
options for the remaining related options that did not previously have
one.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_SD_BOOT
CONFIG_SD_BOOT_QSPI
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Use moveconfig.py script to convert CONFIG_SYS_FMAN_FW_ADDR,
CONFIG_SYS_QE_FW_ADDR and CONFIG_SYS_QE_FMAN_FW_LENGTH to Kconfig and
move these entries to defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
LS1046A-QDS has CONFIG_SPI_FLASH_SST, CONFIG_SPI_FLASH_EON and
CONFIG_SPI_FLASH_STMICRO defines present in header. Move these entries
from header to defconfigs.
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
[Rebased]
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_RAMBOOT_PBL
CONFIG_SYS_FSL_PBL_PBI
CONFIG_SYS_FSL_PBL_RCW
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
Convert SYS_I2C_EARLY_INIT to Kconfig, and make it depend on
SPL_SYS_I2C_LEGACY. Remove the weak implementation as it's either
something that needs to exist for real, or shouldn't be called.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson <stcarlso@linux.microsoft.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CMD_GPIO for board ls1046aqds
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
CONFIG_ENV_OVERWRITE disables write protection on various environment
variables like "ethaddr" and "serial".
Enable this config in LS1046A and LS1012A defconfigs. This resolves an
error while setting multiple values of "ethaddr" variable.
Before the change:
=> setenv ethaddr 00:E0:0C:00:06:0
=> setenv ethaddr 00:E0:0C:00:06:1
Error: Can't overwrite "ethaddr"
Error inserting "ethaddr" variable, errno=1
After the change:
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Enable CONFIG_SPI_FLASH_SPANSION in defconfigs of LS1046ARDB and
LS1046AQDS which have two spansion flases i.e s25fs512s each of size
64M.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1046A
In commit <db4080d56dec>, SPL_FSL_PBL is removed from the configs of
some LayerScape platforms. Actually, SPL_FSL_PBL is needed for SD/NAND
boot on LS1021A/LS1043A/LS1046A to create boot binary having SPL binary
in PBI format concatenated with u-boot binary. SPL_FRAMEWORK is used on
these platforms too.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
