path: root/configs/ls1046aqds_sdcard_ifc_defconfig
2016-09-14armv8: ls1046aqds: Add LS1046AQDS board supportShaohui Xie
LS1046AQDS Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports PCIe: supports Gen 1 and Gen 2 SATA 3.0: one SATA 3.0 port USB 3.0: two micro AB connector and one type A connector UART: supports two UARTs up to 115200 bps for console Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
