Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_ENV_OVERWRITE disables write protection on various environment
variables like "ethaddr" and "serial".
Enable this config in LS1046A and LS1012A defconfigs. This resolves an
error while setting multiple values of "ethaddr" variable.
Before the change:
=> setenv ethaddr 00:E0:0C:00:06:0
=> setenv ethaddr 00:E0:0C:00:06:1
Error: Can't overwrite "ethaddr"
Error inserting "ethaddr" variable, errno=1
After the change:
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
CONFIG_ENV_ADDR helps in picking environment from flash before DDR init.
The macro value is already defined in ls1046ardb_tfa_defconfig, also
define the value as 0x40300000 in qspi_defconfig.
ls1046aqds has one spansion flash "S25FL128S_64K" of size 16M with
sector size 64K. Correct ENV_ADDR and ENV_SECT_SIZE value for QSPI and
TFA defconfigs of the board.
Enable CONFIG_SPI_FLASH_SPANSION in defconfigs of LS1046ARDB and
LS1046AQDS which have two spansion flases i.e s25fs512s each of size
64M.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1046A
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Update mtd-id for QSPI nor due to change introduced in mtd/spi in
linux 5.0. commit 84d043185dbe
("spi: Add a driver for the Freescale/NXP QuadSPI controller")
This modification is only for linux kernel version >= 5.0. To use
bootargs for kernel < 5.0, use the following bootargs
CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0
earlycon=uart8250,mmio,0x21c0500
mtdparts=1550000.quadspi:2m(uboot),14m(free)"
CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:2m(uboot),14m(free)"
EFI applications need bounce buffers to work properly on these
platforms.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1046ardb
and ls1046aqds defconfigs that missing one of them or more.
enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK
Support sata for all ls1046a defconfigs
Signed-off-by: Peng Ma <peng.ma@nxp.com>
This enables the folowing to Kconfig:
CONFIG_BLK
CONFIG_DM_MMC
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
4K erase size is used only in case of hydrid mode which is not
supported on any NXP platform with flash "s25fs512s".
Supported mode is uniform sector, with erase size 256kiB.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Move the macro to defconfig to take effect globally.
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
CONFIG_ENV_IS_IN_SPI_FLASH
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
