CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
Use moveconfig.py script to convert CONFIG_SYS_FMAN_FW_ADDR,
CONFIG_SYS_QE_FW_ADDR and CONFIG_SYS_QE_FMAN_FW_LENGTH to Kconfig and
move these entries to defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_NAND_FSL_ELBC
CONFIG_NAND_FSL_IFC
Note that a number of PowerPC platforms had previously enabled
CONFIG_NAND_FSL_ELBC without CONFIG_MTD_RAW_NAND, and now they no longer
enable the option, reducing the size of a few functions.
CONFIG_SYS_NAND_ONFI_DETECTION
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
Enable CMD_GPIO for board ls1043ardb
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb,
ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb.
- Add GICv3 support for ls1028a, ls2088a, ls1088a.
- Add lpuart support on ls1028aqds.
- Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based
platforms.
Enable DM_ETH on all the defconfigs for the LS1043ARDB board.
Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com>
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1043A
setexpr command is used while running secure boot
(chain of trust with confidentiality) feature.
Enable CONFIG_CMD_SETEXPR to enable setexpr command.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Enabling TFABOOT configuration will compile-in a call to nand_read in
the boot sequence. Handle the situation by also selecting officially
the raw NAND core in this case.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict
with UEFI secure boot.
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
CONFIG_SF_DEFAULT_MODE
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
EFI applications need bounce buffers to work properly on these
platforms.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
TFABOOT support includes:
- ls1043ardb_tfa_defconfig to be loaded by trusted firmware
- environment address and size changes for TFABOOT
- FMAN and QE address changes for TFABOOT
- define BOOTCOMMAND for TFABOOT
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
