The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
Enable CMD_GPIO for board ls1043ardb
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb,
ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb.
- Add GICv3 support for ls1028a, ls2088a, ls1088a.
- Add lpuart support on ls1028aqds.
- Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based
platforms.
Enable DM_ETH on all the defconfigs for the LS1043ARDB board.
Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com>
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1043A
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
In commit <db4080d56dec>, SPL_FSL_PBL is removed from the configs of
some LayerScape platforms. Actually, SPL_FSL_PBL is needed for SD/NAND
boot on LS1021A/LS1043A/LS1046A to create boot binary having SPL binary
in PBI format concatenated with u-boot binary. SPL_FRAMEWORK is used on
these platforms too.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
At present there is only one control for this and it is used for both SPL
and TPL. But SPL might have a lot more space than TPL so the extra cost of
a full printf() might be acceptable.
Split the option into two, providing separate SPL and TPL controls. The
TPL setting defaults to the same as SPL.
The USE_TINY_PRINTF symbol only changes things within SPL and TPL
builds, so make it depend on that support. Next, make it default as
within these cases we should rarely have need of more advanced print
formats outside of the debug context.
To do this, in a few cases we need to correct our Kconfig dependencies
as we had cases of non-SPL targets select'ing this symbol. Finally, in
the case of a few boards we really do need the full printf
functionality.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
EFI applications need bounce buffers to work properly on these
platforms.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G.
Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
This enables the folowing to Kconfig:
CONFIG_BLK
CONFIG_DM_MMC
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
