path: root/configs/ls1043ardb_defconfig
2017-01-18fsl PPA: enable PPA for ls1043ardb and ls1046ardbHou Zhiqiang
Enable PPA for ls1043ardb NOR boot and ls1046ardb QSPI boot. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1043a: Enable PCIe and E1000 in defconfigsMinghuan Lian
The patch enables PCIe and E1000 in ls1043a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03cmd: move CMD_PXE to KconfigYann E. MORIN
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs. However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device. However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable. But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS. Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Joe Hershberger <joe.hershberger@ni.com> [trini: Make it select MENU, run moveconfig.py] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-06armv8: fsl-layerscape: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and realted options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06armv8: ls1043: Enable CONFIG_DM_USB in defconfigsSriram Dash
Enables driver model flag CONFIG_DM_USB for LS1043A platform defconfigs. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-30armv8/ls1043ardb: add DSPI supportGong Qianyu
Use the U-Boot Driver Model. Just enable Freescale DSPI driver and set DSPI related parameters in dts file. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8/ls1043ardb: dts: add dtb supportGong Qianyu
Reuse dts files from ls1043a linux kernel. Some parts in dts files may not be needed by U-Boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add LS1043ARDB board supportMingkai Hu
LS1043ARDB Specification: ------------------------- Memory subsystem: * 2GByte DDR4 SDRAM (32bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * XFI 10G port * QSGMII with 4x 1G ports * Two RGMII ports PCIe: * PCIe2 (Lanes C) to mini-PCIe slot * PCIe3 (Lanes D) to PCIe slot USB 3.0: two super speed USB 3.0 type A ports UART: supports two UARTs up to 115200 bps for console Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
