path: root/configs/ls1043ardb_defconfig
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-30armv8/ls1043ardb: add DSPI supportGong Qianyu
Use the U-Boot Driver Model. Just enable Freescale DSPI driver and set DSPI related parameters in dts file. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8/ls1043ardb: dts: add dtb supportGong Qianyu
Reuse dts files from ls1043a linux kernel. Some parts in dts files may not be needed by U-Boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add LS1043ARDB board supportMingkai Hu
LS1043ARDB Specification: ------------------------- Memory subsystem: * 2GByte DDR4 SDRAM (32bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * XFI 10G port * QSGMII with 4x 1G ports * Two RGMII ports PCIe: * PCIe2 (Lanes C) to mini-PCIe slot * PCIe3 (Lanes D) to PCIe slot USB 3.0: two super speed USB 3.0 type A ports UART: supports two UARTs up to 115200 bps for console Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
