path: root/configs/ls1043aqds_sdcard_ifc_defconfig
2015-11-30armv8/ls1043aqds: add LS1043AQDS board supportShaohui Xie
LS1043AQDS Specification: ------------------------- Memory subsystem: * 2GByte DDR4 DIMM * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * Two RGMII ports * XFI 10G port * SGMII * QSGMII with 4x 1G ports PCIe: supports Gen 1 and Gen 2 SATA 3.0: one SATA 3.0 port USB 3.0: two micro AB connector and one type A connector UART: supports two UARTs up to 115200 bps for console Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> [York Sun: Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
