Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Some boards' defconfig files are out of order. Clean this up.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Various boards have the wrong Kconfig ordering now. To avoid a misleading
diff in the next patch, reorder the configuration correctly.
Enable three DSPI flash memories on board.
Commands:
=> sf probe 1:0
SF: Detected N25Q128A with page size 256 Bytes,
erase size 64 KiB, total 16 MiB
=> sf probe 1:1
SF: Detected SST25WF040B with page size 256 Bytes,
erase size 4 KiB, total 512 KiB
=> sf probe 1:2
SF: Detected EN25S64 with page size 256 Bytes,
erase size 64 KiB, total 8 MiB
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
Reviewed-by: York Sun <york.sun@nxp.com>
LS1043AQDS Specification:
Memory subsystem:
* 2GByte DDR4 DIMM
* 128 Mbyte NOR flash single-chip memory
* 512 Mbyte NAND flash
* 16 Mbyte high-speed SPI flash
* SD connector to interface with the SD memory card
Ethernet:
* Two RGMII ports
* XFI 10G port
* SGMII
* QSGMII with 4x 1G ports
PCIe: supports Gen 1 and Gen 2
SATA 3.0: one SATA 3.0 port
USB 3.0: two micro AB connector and one type A connector
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com>
Signed-off-by: Hou Zhiqiang <B48286@freescale.com>
[York Sun: Add CONFIG_SYS_NS16550=y in defconfig]
Reviewed-by: York Sun <yorksun@freescale.com>
