path: root/configs/ls1028aqds_tfa_lpuart_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-27pci: layerscape: Add specific config entry for RC and EP mode driverHou Zhiqiang
Add Root Complex and Endpoint mode specific config entries, such that it's feasible to enable the RC and/or EP mode driver indepently. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-06-26Convert CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-08treewide: mem: Enable MEMTEST via defconfigMichal Simek
There is no reason to enable MEMTEST from headers when was converted to Kconfig already. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-05-08configs: Resync with savedefconfigTom Rini
2020-04-29configs: ls1028aqds: add lpuart configYuantian Tang
Add lpuart config to enable lpuart feature. Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Signed-off-by: Yuantian Tang <andy.tang@nxp.com>. Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
