There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in
SD boot now. For the customer's demand, QSPI needs to be supported in SD
boot too.
This patch adds QSPI or IFC support in SD boot according to the
corresponding defconfig. For detail, ls1021atwr_sdcard_ifc_defconfig is
used to support IFC in SD boot and ls1021atwr_sdcard_qspi_defconfig is
used to support QSPI in SD boot.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
