path: root/configs/ls1021atwr_nor_lpuart_defconfig
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-18arm: ls1021a: Enable CONFIG_OF_LIBFDT and CONFIG_FIT in defconfigAlison Wang
In defconfig, enable CONFIG_OF_LIBFDT to support booting DT linux kernel and enable COFNIG_FIT to support FIT image. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-20arm: ls1021atwr: Enable driver model lpuart serial driverBin Meng
Convert ls1021atwr_nor_lpuart to driver model support. As a start, enable lpuart serial port driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alison Wang <alison.wang@nxp.com> Tested-by: Alison Wang <alison.wang@nxp.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-20serial: lpuart: Move CONFIG_FSL_LPUART to KconfigBin Meng
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-23arm: ls102xa: Add LPUART support for LS1021ATWR boardAlison Wang
This patch adds LPUART support for LS1021ATWR board. For ls1021atwr_nor_lpuart_defconfig, LPUART is used as the console. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
