path: root/configs/ls1021atwr_nor_defconfig
2016-01-20arm: ls1021atwr: Split off board device treeBin Meng
Move /chosen node out of the board device tree. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-20arm: ls1021atwr: Convert to driver model and enable serial supportBin Meng
Convert ls1021atwr_nor to driver model support. As a start, enable ns16550 serial port driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-08arm: ls102xa: Add basic support for LS1021ATWR boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021ATWR board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Chen Lu <chen.lu@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com>
