path: root/configs/ls1021aqds_sdcard_qspi_defconfig
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-02-19configs: ls1021a: enable sata configs for all ls1021a defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1021a defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls1021a defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-11Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-08-09dm: arm: ls1021a: Move to driver model for USBAlison Wang
This patch enables driver model for USB in defconfigs for LS1021A platforms. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-14Convert CONFIG_FSL_DCU_FB to KconfigSanchayan Maity
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB and convert it to Kconfig. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2017-01-18arm: ls1021a: Enable PCIe in defconfigsMinghuan Lian
The patch enables PCIe in ls1021a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-06armv7: ls1021a: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and related config options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
