path: root/configs/ls1021aqds_sdcard_ifc_defconfig
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-11Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-08-09dm: arm: ls1021a: Move to driver model for USBAlison Wang
This patch enables driver model for USB in defconfigs for LS1021A platforms. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-14Convert CONFIG_FSL_DCU_FB to KconfigSanchayan Maity
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB and convert it to Kconfig. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2017-01-18arm: ls1021a: Enable PCIe in defconfigsMinghuan Lian
The patch enables PCIe in ls1021a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-06armv7: ls1021a: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and related config options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
2016-06-28configs: Re-sync after boot menu changesTom Rini
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-18arm: ls1021a: Enable CONFIG_OF_LIBFDT and CONFIG_FIT in defconfigAlison Wang
In defconfig, enable CONFIG_OF_LIBFDT to support booting DT linux kernel and enable COFNIG_FIT to support FIT image. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24arm: ls1021a: Add QSPI or IFC support in SD boot for LS1021AQDS boardAlison Wang
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in SD boot now. For the customer's demand, QSPI needs to be supported in SD boot too. This patch adds QSPI or IFC support in SD boot according to the corresponding defconfig. For detail, ls1021aqds_sdcard_ifc_defconfig is used to support IFC in SD boot and ls1021aqds_sdcard_qspi_defconfig is used to support QSPI in SD boot. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
