As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported
in SD boot now. For the customer's demand, QSPI needs to be supported
in SD boot too.
This patch adds QSPI or IFC support in SD boot according to the
corresponding defconfig. For detail, ls1021aqds_sdcard_ifc_defconfig
is used to support IFC in SD boot and ls1021aqds_sdcard_qspi_defconfig
is used to support QSPI in SD boot.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Split duart configuration as device tree file. Move /chosen node
out of board commone device tree. Convert ls1021aqds nor and SD
configurations to driver model support (qspi already uses DM).
Enable ns16550 DM serial driver for nor configurations.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Alison Wang <alison.wang@nxp.com>
CC: Bin Meng <bmeng.cn@gmail.com>
Reviewed-by: Alison Wang <alison.wang@nxp.com>
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
This patch adds SD boot support for LS1021AQDS board. SPL
framework is used. PBL initialize the internal RAM and copy
SPL to it, then SPL initialize DDR using SPD and copy u-boot
from SD card to DDR, finally SPL transfer control to u-boot.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
