We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_TSEC_ENET option to Kconfig.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This patch enables driver model for USB in defconfigs for LS1021A
platforms.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB
and convert it to Kconfig.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
Reviewed-by: Alison Wang <alison.wang@nxp.com>
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
The patch enables PCIe in ls1021a defconfigs and
removes unused PCIe related macro defines.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
Signed-off-by: York Sun <york.sun@nxp.com>
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
Move DDR3, DDR4 and related config options to Kconfig and clean up
existing uses.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
In defconfig, enable CONFIG_OF_LIBFDT to support booting DT linux
kernel and enable COFNIG_FIT to support FIT image.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Split duart configuration as device tree file. Move /chosen node
out of board commone device tree. Convert ls1021aqds nor and SD
configurations to driver model support (qspi already uses DM).
Enable ns16550 DM serial driver for nor configurations.
CC: Alison Wang <alison.wang@nxp.com>
CC: Bin Meng <bmeng.cn@gmail.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Some boards' defconfigs are disordered. Reorder them.
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
Several files are out of order. This means that when the moveconfig tool
moves CONFIG options to Kconfig it generates a large diff. To avoid this,
reorder the files first.
PI and QSPI only work when boot from QSPI on ls1021a.
This patch only enable options in qspi boot defconfig.
Signed-off-by: Haikun Wang <haikun.wang@freescale.com>
Tested-by: Haikun Wang <haikun.wang@freescale.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
them from include/configs.
