path: root/configs/ls1021aqds_qspi_defconfig
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-30defconfig: ls1021a: Add OF_CONTROL and DM supportHaikun Wang
PI and QSPI only work when boot from QSPI on ls1021a. This patch only enable options in qspi boot defconfig. Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2014-12-11arm: ls102xa: Add QSPI boot support for LS1021AQDS/TWR boardAlison Wang
This patch adds QSPI boot support for LS1021AQDS/TWR board. The QSPI boot image need to be programmed into the QSPI flash first. Then the booting will start from QSPI memory space. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
