path: root/configs/ls1021aqds_nor_SECURE_BOOT_defconfig
2014-10-16ls102x: Add support for secure boot and enable blob commandRuchika Gupta
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
