path: root/configs/ls1021aqds_ddr4_nor_lpuart_defconfig
2015-04-21ls102xa: ddr4: Use LPUART as console output to verify DCU driverAlison Wang
On QDS board with DDR4 DIMM, LPUART is used as console output to verify DCU driver. This patch adds ls1021aqds_ddr4_nor_lpuart_defconfig for this support. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
