path: root/configs/ls1021aqds_ddr4_nor_defconfig
2016-08-07arm: ls1021a: Enable CONFIG_DM_USB in defconfigsRajesh Bhagat
Enables driver model flag CONFIG_DM_USB for LS1021A platform defconfigs. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-18arm: ls1021a: Enable CONFIG_OF_LIBFDT and CONFIG_FIT in defconfigAlison Wang
In defconfig, enable CONFIG_OF_LIBFDT to support booting DT linux kernel and enable COFNIG_FIT to support FIT image. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-23arm: ls1021aqds: Convert to driver model and enable serial supportYork Sun
Split duart configuration as device tree file. Move /chosen node out of board commone device tree. Convert ls1021aqds nor and SD configurations to driver model support (qspi already uses DM). Enable ns16550 DM serial driver for nor configurations. Signed-off-by: York Sun <york.sun@nxp.com> CC: Alison Wang <alison.wang@nxp.com> CC: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2014-09-25board/ls1021aqds: Add DDR4 supportYork Sun
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig for this variant to enable DDR4 support. RAW timing parameters are not added for DDR4. The board timing parameters are only tuned for single- rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM availability. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com>
