path: root/configs/ls1021aqds_ddr4_nor_defconfig
2022-07-05Convert CONFIG_PCIE1 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PCIE1 CONFIG_PCIE2 CONFIG_PCIE3 CONFIG_PCIE4 CONFIG_PCI1 Signed-off-by: Tom Rini <trini@konsulko.com>
2022-07-05Convert CONFIG_LAYERSCAPE_NS_ACCESS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_LAYERSCAPE_NS_ACCESS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_CBSIZE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_CBSIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_PBSIZE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_PBSIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-21configs: set CONFIG_COUNTER_FREQUENCYPeng Fan
Set CONFIG_COUNTER_FREQUENCY according to COUNTER_FREQUENCY in config header file. Signed-off-by: Peng Fan <peng.fan@nxp.com> [trini: Re-run migration]
2022-04-13configs: Resync with savedefconfigTom Rini
2022-04-12Layerscape: Enable Job ring driver model.Gaurav Jain
LS(1021/1012/1028/1043/1046/1088/2088), LX2160, LX2162 platforms are enabled with JR driver model. removed sec_init() call from board files. sec is initialized based on job ring information processed from device tree. Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: Michael Walle <michael@walle.cc>
2022-04-08configs: Resync with savedefconfigTom Rini
2022-04-08Convert CONFIG_FSL_QIXIS et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_FSL_QIXIS CONFIG_QIXIS_I2C_ACCESS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01configs: Resync with savedefconfigTom Rini
2022-03-18Convert CONFIG_ETHPRIME to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ETHPRIME This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME similar to other options that are not always set and control environment variables. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-03Convert CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-02-10nvme: Split out PCI supportMark Kettenis
Apple SoCs have an integrated NVMe controller that isn't connected over a PCIe bus. In preparation for adding support for this NVMe controller, split out the PCI support into its own file. This file is selected through a new CONFIG_NVME_PCI Kconfig option, so do a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI. Signed-off-by: Mark Kettenis <kettenis@openbsd.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested on: Macbook Air M1 Tested-by: Simon Glass <sjg@chromium.org>
2022-02-09sata: Rearrange Kconfig for SATASimon Glass
Move the SATA options inside an 'if SATA' part, so they are grouped. Fix the 'Complient' typo while we are here. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-21configs: Migrate CONFIG_SYS_MAX_FLASH_BANKS to KconfigPatrick Delaunay
Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries to defconfigs. Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> [trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-27Finish conversion of CONFIG_SYS_CLK_FREQ to KconfigTom Rini
In order to finish moving this symbol to Kconfig for all platforms, we need to do a few more things. First, for all platforms that define this to a function, introduce CONFIG_DYNAMIC_SYS_CLK_FREQ, similar to CONFIG_DYNAMIC_DDR_CLK_FREQ and populate clock_legacy.h. This entails also switching all users from CONFIG_SYS_CLK_FREQ to get_board_sys_clk() and updating a few preprocessor tests. With that done, all platforms that define a value here can be converted to Kconfig, and a fall-back of zero is sufficiently safe to use (and what is used today in cases where code may or may not have this available). Make sure that code which calls this function includes <clock_legacy.h> to get the prototype. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-27Convert CONFIG_CONS_INDEX et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX CONFIG_DEBUG_UART_CLOCK CONFIG_FSL_TZPC_BP147 CONFIG_GENERIC_ATMEL_MCI CONFIG_IDENT_STRING CONFIG_LIBATA CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE CONFIG_LPC32XX_GPIO CONFIG_MP CONFIG_MPC8XXX_GPIO CONFIG_MTD_PARTITIONS CONFIG_MVGBE CONFIG_MXC_GPIO CONFIG_NR_DRAM_BANKS CONFIG_OF_BOARD_SETUP CONFIG_OF_STDOUT_VIA_ALIAS CONFIG_OF_SYSTEM_SETUP CONFIG_PREBOOT CONFIG_ROCKCHIP_SERIAL CONFIG_RTC_ENABLE_32KHZ_OUTPUT CONFIG_RTC_MV CONFIG_SCSI_AHCI CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_SPEED CONFIG_SOFT_SPI CONFIG_SPI_FLASH_EON CONFIG_SPI_FLASH_MACRONIX CONFIG_SPI_FLASH_MTD CONFIG_SPI_FLASH_SPANSION CONFIG_SPI_FLASH_SST CONFIG_SPI_FLASH_STMICRO CONFIG_SUPPORT_RAW_INITRD CONFIG_SYS_ARCH_TIMER CONFIG_SYS_BOARD CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_DCACHE_OFF CONFIG_SYS_FDT_SAVE_ADDRESS CONFIG_SYS_FLASH_CFI CONFIG_SYS_FSL_ERRATUM_ESDHC135 CONFIG_SYS_HAS_SERDES CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_LITTLE_ENDIAN CONFIG_SYS_LOAD_ADDR CONFIG_SYS_MMCSD_FS_BOOT_PARTITION CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR CONFIG_SYS_NS16550 CONFIG_SYS_PLLFIN CONFIG_SYS_SPI_U_BOOT_OFFS CONFIG_TIMER_SYS_TICK_CH CONFIG_USB_EHCI_FSL CONFIG_U_QE CONFIG_VERSION_VARIABLE Signed-off-by: Tom Rini <trini@konsulko.com>
2021-11-12configs: Resync with savedefconfigTom Rini
2021-11-09configs: fsl: migrate FMAN/QE specific defines to KconfigRajesh Bhagat
Use moveconfig.py script to convert CONFIG_SYS_FMAN_FW_ADDR, CONFIG_SYS_QE_FW_ADDR and CONFIG_SYS_QE_FMAN_FW_LENGTH to Kconfig and move these entries to defconfigs. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> [Rebased] Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2021-11-01configs: Resync with savedefconfigTom Rini
2021-10-06Convert CONFIG_NAND_FSL_ELBC et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_NAND_FSL_ELBC CONFIG_NAND_FSL_IFC Note that a number of PowerPC platforms had previously enabled CONFIG_NAND_FSL_ELBC without CONFIG_MTD_RAW_NAND, and now they no longer enable the option, reducing the size of a few functions. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-10-06Convert CONFIG_SYS_NAND_ONFI_DETECTION to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_NAND_ONFI_DETECTION Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31Convert CONFIG_SYS_MALLOC_LEN to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MALLOC_LEN Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-08-31Convert CONFIG_SKIP_LOWLEVEL_INIT et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SKIP_LOWLEVEL_INIT CONFIG_SKIP_LOWLEVEL_INIT_ONLY In order to do this, we need to introduce SPL and TPL variants of these options so that we can clearly disable these options only in SPL in some cases, and both instances in other cases. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31Convert CONFIG_SYS_LOAD_ADDR to KconfigTom Rini
Now that we have consistent usage, migrate this symbol to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-08-31nxp: Migrate a number of DDR related symbols to KconfigTom Rini
- Guard most of the options in drivers/ddr/fsl/Kconfig with SYS_FSL_DDR || SYS_FSL_MMDC. - Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER to Kconfig. - Clean up the logic for including the DDR_ECC_CMD code. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31nxp: Migrate CONFIG_DDR_CLK_FREQ to KconfigTom Rini
As this symbol can either be a fixed value or the function get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ to that value and now include/clock_legacy.h contains the function prototype or defines get_board_ddr_clk() to that static value. Update callers to test for DYNAMIC or STATIC. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-30Convert CONFIG_I2C_SET_DEFAULT_BUS_NUM et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_I2C_SET_DEFAULT_BUS_NUM CONFIG_I2C_DEFAULT_BUS_NUMBER Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-30Convert CONFIG_SYS_I2C_MXC et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_I2C_MXC CONFIG_SYS_I2C_MXC_I2C1 CONFIG_SYS_I2C_MXC_I2C2 CONFIG_SYS_I2C_MXC_I2C3 CONFIG_SYS_I2C_MXC_I2C4 Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-30Convert CONFIG_SYS_I2C_LEGACY to Kconfig and add CONFIG_[ST]PL_SYS_I2C_LEGACYTom Rini
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot have SYS_I2C_LEGACY and DM_I2C at the same time, introduce CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only in SPL. Finally, for some PowerPC cases we also need CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to one or more symbols. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-30Convert CONFIG_SYS_I2C_EEPROM_ADDR et al to KconfigTom Rini
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR based on current usage. - Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS to Kconfig. We move these symbols around a bit and add appropriate dependencies to them. In some cases, we now add a correct default value as well. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-30Convert CONFIG_ID_EEPROM to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ID_EEPROM Signed-off-by: Tom Rini <trini@konsulko.com>
2021-07-26configs: Resync with savedefconfigTom Rini
2021-07-20board: freescale: ls1021aqds: Update I2C mux configStephen Carlson
Updates the board configuration to enable use of the PCA9547 I2C mux. Signed-off-by: Stephen Carlson <stcarlso@linux.microsoft.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2021-05-11configs: Resync with savedefconfigTom Rini
2021-02-15configs: Resync with savedefconfigTom Rini
2021-02-08configs: ls1021aqds: enable CMD_GPIOBiwen Li
Enable CMD_GPIO for board ls1021aqds Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-11-30configs: Resync with savedefconfigTom Rini
2020-10-29configs: Resync with savedefconfigTom Rini
2020-10-29Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- Bug fixes and updates on vid, ls1088a lx2160a and other layerscape platforms. - Add optee_rpmb support for LX2 & Kontron sl28 support
2020-10-26ls1021aqds: disable obsolete VIDEO configAnatolij Gustschin
DM_VIDEO conversion deadline has passed, disable VIDEO config. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Alison Wang <alison.wang@nxp.com>
2020-10-23configs: Enable NVME support for Layerscape platformsWasim Khan
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape platforms Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-27pci: layerscape: Add specific config entry for RC and EP mode driverHou Zhiqiang
Add Root Complex and Endpoint mode specific config entries, such that it's feasible to enable the RC and/or EP mode driver indepently. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
