Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
Tested-by: Adam Ford <aford173@gmail.com>
CONFIG_ENV_IS_IN_FLASH
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB
and convert it to Kconfig.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
Reviewed-by: Alison Wang <alison.wang@nxp.com>
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
The patch enables PCIe in ls1021a defconfigs and
removes unused PCIe related macro defines.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
Signed-off-by: York Sun <york.sun@nxp.com>
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
Move DDR3, DDR4 and related config options to Kconfig and clean up
existing uses.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Enables driver model flag CONFIG_DM_USB for LS1021A
platform defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
In defconfig, enable CONFIG_OF_LIBFDT to support booting DT linux
kernel and enable COFNIG_FIT to support FIT image.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Some boards' defconfig files are out of order. Clean this up.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Split duart configuration as device tree file. Move /chosen node
out of board commone device tree. Convert ls1021aqds nor and SD
configurations to driver model support (qspi already uses DM).
Enable ns16550 DM serial driver for nor configurations.
CC: Alison Wang <alison.wang@nxp.com>
CC: Bin Meng <bmeng.cn@gmail.com>
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig
for this variant to enable DDR4 support. RAW timing parameters are not
added for DDR4. The board timing parameters are only tuned for single-
rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM
availability.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Alison Wang <alison.wang@freescale.com>
