path: root/configs/ls1012ardb_qspi_defconfig
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-22configs: ls1012a: add pfe configuration for LS1012ACalvin Johnson
Add configurations for PFE. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Anjaneyulu Jagarlmudi <anji.jagarlmudi@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-13arm64: ls1012ardb: Add distro boot supportRajesh Bhagat
Include common config_distro_defaults.h and config_distro_bootcmd.h for u-boot enviroments to support automatical distro boot which scan boot.scr from external storage devices(e.g. SD and USB) and execute autoboot script. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-10configs: Re-sync CONFIG_CMD_IMLS with moveconfigTuomas Tynkkynen
The option is specified in Kconfig, but still a few config header files are overriding the choice by #undef'ing it. Re-sync the option with moveconfig to rid of the #undefs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-02-03armv8: ls1012a: Add support of PPAPrabhakar Kushwaha
The PPA implements PSCI which requires for power managment. Added support of PPA for LS1012AQDS, LS1012ARDB and LS1012AFRDM. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18configs: ls1012a: enable driver model for eSDHCYangbo Lu
Enable driver model for eSDHC on ls1012a rdb and qds boards. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1012: Enable CONFIG_DM_USB in defconfigsTang Yuantian
Enables driver model flag CONFIG_DM_USB for LS1012A platform in defconfigs. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18arm: ls1012a: Enable PCIe and E1000 in defconfigsMinghuan Lian
The patch enables PCIe and E1000 in ls1012a defconfigs and removes unused PCIe related macro defines Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-05armv8: QSPI: Add AHB bus 16MB+ size supportYuan Yao
The default configuration for QSPI AHB bus can't support 16MB+. But some flash on NXP layerscape board are more than 16MB. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-28configs: Re-sync after boot menu changesTom Rini
2016-06-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Modified: configs/ls1012afrdm_qspi_defconfig configs/ls1012aqds_qspi_defconfig configs/ls1012ardb_qspi_defconfig include/configs/ls1012afrdm.h include/configs/ls1012aqds.h include/configs/ls1012ardb.h Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-03armv8: ls1012a: Add support of ls1012ardb boardPrabhakar Kushwaha
QorIQ LS1012A Reference Design System (LS1012ARDB) is a high-performance development platform, with a complete debugging environment. The LS1012ARDB board supports the QorIQ LS1012A processor and is optimized to support the high-bandwidth DDR3L memory and a full complement of high-speed SerDes ports. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
