Apple SoCs have an integrated NVMe controller that isn't connected
over a PCIe bus. In preparation for adding support for this NVMe
controller, split out the PCI support into its own file. This file
is selected through a new CONFIG_NVME_PCI Kconfig option, so do
a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
Move the SATA options inside an 'if SATA' part, so they are grouped.
Fix the 'Complient' typo while we are here.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_QSPI_BOOT
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
Enable CMD_GPIO for ls1012ardb
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
CONFIG_ENV_OVERWRITE disables write protection on various environment
variables like "ethaddr" and "serial".
Enable this config in LS1046A and LS1012A defconfigs. This resolves an
error while setting multiple values of "ethaddr" variable.
Before the change:
=> setenv ethaddr 00:E0:0C:00:06:0
=> setenv ethaddr 00:E0:0C:00:06:1
Error: Can't overwrite "ethaddr"
Error inserting "ethaddr" variable, errno=1
After the change:
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
All LS1012A board variants have same CONFIG_ENV_SECT_SIZE and
CONFIG_ENV_SIZE values. If both config values are same, flash
environment cannot be saved. Since, CONFIG_ENV_SECT_SIZE needs to be
same as that of flash sector size, this entry cannot be changed.
Reduce CONFIG_ENV_SIZE value to 0x2000. This also helps in making config
value aligned with other boards environemt size.
Signed-off-by: Ashish Kumar <Ashish.kumar@nxp.com>
Since CONFIG_FSL_QSPI is already enabled for LS1012A in defconfigs. Also
enable CONFIG_SPI_FLASH_SPANSION for LS1012A boards having spansion
flashes.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1012A
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable the config for ls1012ardb as the entry got missed earlier.
Fixes: 8d8ee47e03 ("env: Add CONFIG_SYS_RELOC_GD_ENV_ADDR symbol")
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
- Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC.
- Few bug fixes and updates related to SPI, hwconfig, ethernet,
fsl-layerscape, pci, icid, PSCI
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict
with UEFI secure boot.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Enable related configs to support sata DM feature.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
4K erase size is used only in case of hydrid mode which is not
supported on any NXP platform with flash "s25fs512s".
Supported mode is uniform sector, with erase size 256kiB.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
[trini: Re-run migration]
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
[trini: Re-run migration after also including CMD_MEMTEST]
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
