path: root/configs/ls1012aqds_qspi_defconfig
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-10configs: Re-sync CONFIG_CMD_IMLS with moveconfigTuomas Tynkkynen
The option is specified in Kconfig, but still a few config header files are overriding the choice by #undef'ing it. Re-sync the option with moveconfig to rid of the #undefs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-11Convert CONFIG_CMD_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SCSI Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to enable the command, fixing an earlier error. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [trini: Rework to default y if SCSI, drop cl-som-am57x which did not use CMD_SCSI for real] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-02-03armv8: ls1012a: Add support of PPAPrabhakar Kushwaha
The PPA implements PSCI which requires for power managment. Added support of PPA for LS1012AQDS, LS1012ARDB and LS1012AFRDM. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18configs: ls1012a: enable driver model for eSDHCYangbo Lu
Enable driver model for eSDHC on ls1012a rdb and qds boards. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1012: Enable CONFIG_DM_USB in defconfigsTang Yuantian
Enables driver model flag CONFIG_DM_USB for LS1012A platform in defconfigs. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18arm: ls1012a: Enable PCIe and E1000 in defconfigsMinghuan Lian
The patch enables PCIe and E1000 in ls1012a defconfigs and removes unused PCIe related macro defines Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-05armv8: QSPI: Add AHB bus 16MB+ size supportYuan Yao
The default configuration for QSPI AHB bus can't support 16MB+. But some flash on NXP layerscape board are more than 16MB. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-28configs: Re-sync after boot menu changesTom Rini
2016-06-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Modified: configs/ls1012afrdm_qspi_defconfig configs/ls1012aqds_qspi_defconfig configs/ls1012ardb_qspi_defconfig include/configs/ls1012afrdm.h include/configs/ls1012aqds.h include/configs/ls1012ardb.h Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-03armv8: ls1012a: Add support of ls1012aqds boardPrabhakar Kushwaha
QorIQ LS1012A Development System (LS1012AQDS) is a high-performance development platform, with a complete debugging environment. The LS1012AQDS board supports the QorIQ LS1012A processor and is optimized to support the high-bandwidth DDR3L memory and a full complement of high-speed SerDes ports. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
