to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Moved CONFIG_FSL_ESDHC from header files to defconfig files.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1012afrwy
and ls1012afrwy defconfigs that missing one of them or more.
Support sata for all ls1012afrwy defconfigs
Signed-off-by: Peng Ma <peng.ma@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
This is the PR for SPI-NAND changes along with few spi changes.
[trini: Re-sync changes for ls1012afrwy_qspi*_defconfig]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
FRWY-LS1012A belongs to LS1012A family with features 2 1G SGMII PFE
MAC, Micro SD, USB 3.0, DDR, QuadSPI, Audio, UART.
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com>
[yorks: rebase and fix SPDX tag]
[yorks: fix board/freescale/ls1012afrdm/Kconfig]
Reviewed-by: York Sun <york.sun@nxp.com>
