path: root/configs/ls1012afrwy_qspi_defconfig
2019-06-23Move CONFIG_FSL_ESDHC to defconfigYangbo Lu
Moved CONFIG_FSL_ESDHC from header files to defconfig files. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-02-19configs: ls1012afrwy: enable sata configs for all ls1012afrwy defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1012afrwy and ls1012afrwy defconfigs that missing one of them or more. Support sata for all ls1012afrwy defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-09configs: Resync with savedefconfigTom Rini
2018-06-11board: ls1012a: FRWY-LS1012A board supportBhaskar Upadhaya
FRWY-LS1012A belongs to LS1012A family with features 2 1G SGMII PFE MAC, Micro SD, USB 3.0, DDR, QuadSPI, Audio, UART. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> [yorks: rebase and fix SPDX tag] [yorks: fix board/freescale/ls1012afrdm/Kconfig] Reviewed-by: York Sun <york.sun@nxp.com>
