path: root/configs/lion-rk3368_defconfig
2017-11-26rockchip: defconfig: lion-rk3368: sync up with SPL changes for ATFPhilipp Tomsich
This tracks the SPL changes for ATF for the RK3368-uQ7: * renames ATF_SUPPORT to ATF * drops CONFIG_SPL_ATF_TEXT_BASE (now dynamically retrieved from the .itb file) Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-01rockchip: lion-rk3368: defconfig: select PHY_MICREL_KSZ90X1Philipp Tomsich
The RK3368-uQ7 uses a KSZ9031 PHY on-module. Enable PHY_MICREL_KSZ90X1 in the associated defconfig. References: da3b9e7f ("Move PHY_MICREL and PHY_MICREL_KSZ90X1 to Kconfig") Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-01rockchip: lion-rk3368: defconfig: remove duplicate CONFIG_ENV_IS_IN_MMCPhilipp Tomsich
Remove a duplicate CONFIG_ENV_IS_IN_MMC assignment for the lion-rk3368 defconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-18rockchip: lion-rk3368: defconfig: resync w/ OF_LIVE and BOOTSTAGE enabledPhilipp Tomsich
This adds OF_LIVE and BOOTSTAGE support for the RK3368-uQ7 and regenerates the defconfig (picking up a few changes/reorderings) from upstream Kconfig changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-08configs: Resync with savedefconfigTom Rini
2017-08-13rockchip: rk3368: spl: move SPL_LDSCRIPT to KconfigPhilipp Tomsich
With the new way of doing things (i.e. the hierarchical selection of SPL_LDSCRIPT via Kconfig) in place, this moves the SPL_LDSCRIPT setting for the RK3368 from defconfig back into Kconfig. With this done, there should be no lingering cases of SPL_LDSCRIPT outside of Kconfig files. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: lion-rk3368: defconfig: enable DM timer for all stagesPhilipp Tomsich
There is no reasonably robust way (this will be needed so early that diagnostics will be limited) to specify the base-address of the secure timer through the DTS for TPL and SPL. In order to allow us a cleaner way to structure our SPL and TPL stage, we now move to a DM timer driver. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: board: lion-rk3368: add support for the RK3368-uQ7Philipp Tomsich
The RK3368-uQ7 (codenamed 'Lion') is a micro-Qseven (40mm x 70mm, MXM-230 edge connector compatible with the Qseven specification) form-factor system-on-module based on the octo-core Rockchip RK3368. It is designed, supported and manufactured by Theobroma Systems. It provides the following features: - 8x Cortex-A53 (in 2 clusters of 4 cores each) - (on-module) up to 4GB of DDR3 memory - (on-module) SPI-NOR flash - (on-module) eMMC - Gigabit Ethernet (with an on-module KSZ9031 PHY) - USB - HDMI - MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group) - various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...) Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
