path: root/configs/linkit-smart-7688-ram_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-03mips: rename mach-mt7620 to mach-mtmipsWeijie Gao
Currently mach-mt7620 contains only support for mt7628. To avoid confusion, rename mach-mt7620 to mach-mtmips, which means MediaTek MIPS platforms. MT7620 and MT7628 should be distinguished by SOC_MT7620 and SOC_MT7628 because they do not share the same lowlevel codes. Dependencies of four drivers are changed to SOC_MT7628 as these drivers are only used by MT7628. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-04-12mips: mt76xx: linkit-smart-7688: Enable USB and FS supportStefan Roese
This patch enables USB and file-system support on the LinkIt smart MT7688 module for both, the normal and the RAM default config. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-04-12mips: mt76xx: linkit: Add mtd command supportStefan Roese
The new mtd is very useful so let's enable it on the LinkIt Smart 7688 as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Jiri Kastner <cz172638@gmail.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19mips: mt76xx: linkit/gardena: Don't use CONFIG_OF_EMBEDStefan Roese
Building with CONFIG_OF_EMBED generates build warnings, as it should only be used for debugging purposes. So let's move all MT7688 targets to CONFIG_OF_SEPARATE instead with this patch. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-18mips: mt76xx: linkit-smart-7688: Misc updates to dts/config/defconfigStefan Roese
These misc updates include the following changes: - Change baudrate from 57600 to 115200 - Enable MIPS_BOOT_CMDLINE_LEGACY - Enable FIT support - Enable ethernet support - Enable SPI support - Enable GPIO support - Change max image size from 0x40000 to 0x80000 A note about the baudrate change: The original Mediatek U-Boot version used 57600 baud. Lets move to a more common and faster speed of 115200 baud. And remove the "console=" property from the DT as its not needed. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-23mips: Add LinkIt Smart 7688 supportStefan Roese
The LinkIt Smart 7688 modules have a MT7688 SoC with 128 MiB of RAM and 32 MiB of flash (SPI NOR). This patch also includes 2 targets. One is the target that can be programmed into the SPI NOR flash and a 2nd target "xxx-ram" is added to support loading and booting via an already running U-Boot version. This allows easy development and testing without the need to flash the image each time. Signed-off-by: Stefan Roese <sr@denx.de> [fixed and regenerated defconfig files] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
