Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Most of the boards we support with H3/H5 enable DRAM on-die termination,
which is consistent with the high DRAM clocks that are used.
Make it the default (like it's done for other similar platforms) instead
of defining it in each defconfig.
Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Most H3/H5 boards we support have the DRAM ZQ value set to 3881979,
which is also consistent with the default set for the R40.
Make this value the default on H3/H5 instead of 123.
Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
The Libretech ALL-H3-CC has a high density connector for attaching
an eMMC module. The module form factor and connection is specific
to Libretech, and has provisions for split vmmc/vqmmc (core and I/O)
voltage supplies, but this board does not wire the vqmmc side. The
H2+/H3/H5 SoCs do not support alternate I/O voltages for eMMC either.
Only 3.3V is supported. A specific module that ties vqmmc to vmmc,
with both at 3.3V, must be used.
Given that a) eMMC is not designed to be hotplugged, b) power is
always provided on the pins, and c) MMC controllers can deal with
missing cards, we can enable this by default. If a module is attached
it will be picked up by the system.
The device tree change was also submitted to the Linux Kernel and
has already been queued up for 4.19.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
This patch adds a device tree file for the H2+ version of the Libre
Computer Board ALL-H3-CC. It is the same board first introduced in
commit afe27544125e ("sunxi: Add support for Libre Computer Board
ALL-H3-CC H3 ver."), with the H3 SoC replaced with the H2+ SoC, and
has only two 2Gb DDR3 chips instead of four.
The device tree utilizes the common board design file for ALL-H3-CC,
providing just the model strings and SoC specifics.
